Kevin Windrem avatar image
Kevin Windrem asked
VE.Can for Raspberry PI
I'm considering a Rasberry PI4 as a GX Device. and wonder what others are using for touch display and peripherals.
Is a powered hub essential? I'd have the following attached:
1 VE.bus to USB adapter
2 VE.direct to USB adapters
1 VE.Can to USB adapter
1 USB touch interface (TBD)
1 GPS USB
I also wonder what others are doing for a CANbus USB interface. At ~$400, the Victron one isn't cost effective. I found a couple of CANbus interfaces for under $60 on Amazon, one that claims Unix compatibility.
Raspberry Pi
@Kevin Windrem, I've moved this question to the "Modifications Space" to bring it into view of other users of such systems. Cheers!
juanmijm avatar image
juanmijm answered ·
Hello, I am sorry to refloat an old post, but I am interested in this, someone has succeeded and could you tell me which adapter could work?
janieronen avatar image
janieronen answered ·
1. Powered USB hub is not essential as listed adapters are not that power-hungry. But I prefer powered hubs as RPI's own power adapter can be smaller and not lift regulator temps in the RPI board.
2. Did you find a ready-to-go solution to RPI4? I have been reading threads, and looks that there is not yet a ready ported solution for RPI4.
3. Don't have personal experience with CANbus adapters as proposed to use Victron GX-hardware when CANbus is needed. With Cerbo, you can have a cheaper and more reliable setup as no need to use the adapters.
pmhaynes avatar image
pmhaynes answered ·
i was thinking of buying one of these to CANBUS to my Batrium
https://thepihut.com/products/2-channel-isolated-can-hat-for-raspberry-pi
Kevin Windrem answered ·
My RPI 4 is up and running Venus GX. Getting a 7" touch screen was a slam dunk with the help provided here on this forum:
https://community.victronenergy.com/questions/65414/venus-os-raspberry-4-5-mpi5001-calibration-touchsc.html
I found a link to the RPI4 image:
https://updates.victronenergy.com/feeds/tmp/venus-image-raspberrypi4-20191124183952-v2.40~42.rootfs.wic.zip
and more info in this post:
https://community.victronenergy.com/questions/25666/venus-on-raspberry-pi-4.html
I had no luck with a CANbus interface I bought on Amazon:
https://www.amazon.com/gp/product/B07FY4YLPL
So this is on the DO NOT USE list.
There are many on the list here:
https://github.com/victronenergy/venus/wiki/RaspberryPi-CAN-Interfaces
It largely depends on whether you what a hat board or a USB interface.
I went with the CANable USB because it's inexpensive. I picked the isolated version to avoid issues.
Rob Duthie also is working on "Stetson" an adapter board with most of the interfaces you'd find on Cerbo, plus a handful more. But he's waiting on Venus OS RPI4 support for the newer v1.4 board which currently doesn't boot.
Rob Duthie avatar image Rob Duthie commented ·
Hi All
The Rapi 4 they all work OK now.
Regards
Rob D
NZ
Mike Dorsett avatar image
Mike Dorsett answered ·
Beware of some of the cheaper CAN interfaces on the net. Some of the CAN/SPI interfaces use 5V for the SPI levels, this will damage the pi. However, wiht care these can be modified to use 3.3V for the SPI - though the drive to the CAN Buffer chip needs to remain at 5V. If you are up to some delicate hacking, these can be acquired for $35 or so. Does not apply to CAN/USB interfaces.
