capptn avatar image
capptn asked
Venus OS Raspberry 4 - 5" MPI5001, calibration Touchscreen
Hello everybody,
I have already successfully got venus os to run on a Raspberry 4 with the original Raspberry 7 inch display.
But now I want to use a 5 "HDMI display with USB touch.
To be more precise a MPI5001.
I did the following:
config.txt - add this:
framebuffer_width = 800
framebuffer_height = 480
hdmi_force_edid_audio = 1
max_usb_current = 1
hdmi_force_hotplug = 1
config_hdmi_boost = 7
hdmi_group = 2
hdmi_mode = 1
hdmi_mode = 87
hdmi_drive = 1
hdmi_cvt 800 480 60 6 0 0 0
then install tslib:
- first changed /etc/opkg/venus.conf to develop
-than:
opkg update
opkg install qt4-embedded-plugin-mousedriver-tslib
opkg install tslib-calibrate
everything looks fine up to here.
then configured the calibrating files:
TSLIB_FBDEVICE = / dev / fb0
TSLIB_TSDEVICE = / dev / input / touchscreen0
TSLIB_CALIBFILE = / etc / pointercal
TSLIB_CONFFILE = / etc / ts.conf
TSLIB_PLUGINDIR = / usr / lib / ts
and than ts_calibrate
but nothings happend.
what am I doing wrong? Does somebody has any idea?
The touchscreen generally works, I also see a mouse pointer, only the size of the touch area is wrong
Best Regards Fabian
Venus OSRaspberry Pi
capptn avatar image
capptn answered ยท
Hello everybody,
I was able to fix the problem by installing firmware version 2.60 for the Raspberry pi 4.
federico993 avatar image federico993 commented ยท
Hi, are you able to regulate the brightness of the HDMI screen through the Venus software?
0 Likes 0 ยท
