ianddindustries avatar image
ianddindustries asked
Power assist
Hi
I have a system that requires the multiplus to have Ac out only when there is shore power (Ac in) And use the powers assist
The shore power is limited to 10 amps and the system has very short spikes of 15 amps And generally runs at around 6.5 amps so will charge the lithium battery in between spikes
Is there an assistant that can manage this or would the use of a relay be required.
Regards
Grant
powerassist
Paul B avatar image
Paul B answered ·
you just need to adjust the current limit in the Multiplus to 10 amps this is done with a MK3 and the victron VE configure program or you can add a Victron DMC unit which is a remote switch and Knobe
ianddindustries answered ·
Hi , yes but I only want the Ac out to be on when Ac in is present, so the system can’t run on the batteries, and only are only used to power assist.
Wire your loads to ACout2 ?
Hi @IandDIndustries
you can set the unit to 'charge only' this way it will only power up when AC is present on input.
Plus set a 10A input current limit.
Will powerassist work on charge only
ianddindustries avatar image ianddindustries Daniël Boekel (Victron Energy Staff) ♦♦ ·
Hi. Just tested powerassist on charge only and it will only do passthru
Whilst on passthru the input current limit (set to 10 amps) doesn’t not work either.
