Vangelis Beligiannis avatar image
Vangelis Beligiannis asked
SOC jumps 25% higher in minutes!
I have installed an offgrid system with an Easysolar 24/3000 with 472 Ah OPZV batteries and 2Kw panels. There is also a CCGX.
When the day is not 100% sunny the SOC value jumps 25% higher in only 20 minutes. 25% of SOC means around 120Ah that are never charged to the battery through the MPPT.
EasySolar All-in-One
@vbelijohn
I have seen this happen when some battery settings are not quite right.
What do you have as your settings under the internal battery monitor
Vangelis Beligiannis avatar image Vangelis Beligiannis Alexandra ♦ commented ·
Enter Bulk at 90%.
Capacity 472
Charge efficiency 95%
Vangelis Beligiannis answered ·
Enter Bulk at 90%.
Capacity 472
Most OPZV are 85% efficient after 3years drop efficiency 1 to2 % per year or so,m aybe more depending on use though.
Bulk about 80%, they like quite a long absorption stage as well.
