borowar avatar image
borowar asked
SmartShunt 500a Voltage Reading. Error
Hello, thank you for assisting me.
My main question is about the Voltage. In the Victron application the showed voltage is higher than if I measure it directly with a multimeter. It is normal?
For example, Full charged, 100%. Charger floating: VictronConnet 12.77v - Multimeter 12.69
The other question I have is the following. The battery is a 90ah AGM Victron . With a consumption of 5ah in 2h (2.5ah per hour) it tells me that the State of charge is 96% but the voltage has dropped to 12.4v. I do not believe that 12.4v corresponded with the 96%. Rigth?
Let's see if you can help me. Thank you!
SmartShunt
