ac00per avatar image
ac00per asked
BatteryProtect remote reconnect
I have a not-smart BatteryProtect
I'm using it to cut-off a system in mode 7, so when the system voltage drops below 11.8V it cuts out.
Once it has cut out I manually remove heavy loads from the system, allowing the voltage to recover. The problem I have is the system voltage doesn't always go back to above 12.8V (it typically goes back to around 12.6V). Other than increasing the voltage for a bit to above 12.8V, is there a way to reset it? Does using the remote cause it to reconnect? (I don't want to change to mode 1 with 12V reconnect)
Thanks
Battery Protect
