mikeb avatar image
mikeb asked
Connecting Fronius to Color Control GX CCGX
Hi
Setting up a AC coupled primo and colourgx
There must be a easy way of setting up a hardwired situation between the two to allow them to communicate with each other ?
Has anyone any experience with these
As the site it’s going on to needs to be treated like it has no internet no WiFi or router access.
Tried just plugging the two together with a network switch with no success
Regards
Fronius
markus avatar image
markus answered ·
Hi @mikeb,
have a look at:
ccgx:ccgx_fronius
I have (co) written an explanation there. Maybe you post what is not so good to understand, or may be written better and I could improve this manual.
Thank you!
PS.: It is also possible to connect the Fronius to a WiFi. Refer to it's manual to see how.
Markus
mikeb avatar image
mikeb answered ·
Hi thanks for the reply
Not having any success with the link have been trying to follow it.
Is there just a simpler way that’s being over looked
For example connecting the colour gx to the fronuis using the modbus connection block of the fronuis data manager
Not confident that all this ip addressing etc there won’t be drop outs of communication
Regards
mikeb avatar image
mikeb answered ·
The situation is I don’t want to connect the primo or the colour gx to WiFi think is to unreliable and have had the fronuis and colour gx connected with a router and still experiencing the fronuis being lost off the colour gx even tho they have been connected for over 12-13 hours
With a hard wired connection similar to the old way the byd allow to charge and discharge connection was made to the inverter would be a lot more reliable
Regards
markus avatar image
markus answered ·
If you have only one Fronius unit, connect it directly to the CCGX using a LAN cable.
You shouldn't have to care about IP addresses because Link-local addressing should work when you have the latest firmware running on the CCGX.
Should be as easy as "Plug and Play"
Markus
mikeb avatar image
mikeb answered ·
That doesn’t work have had that situation set up and the primo doesn’t register on the colour gx
5 comments
markus avatar image markus ♦♦ commented ·
IP Switch on the Fronius set to "A Position" and latest Firmware on CCGX?
mikeb avatar image mikeb commented ·
Yes latest firmware and postion a
markus avatar image markus ♦♦ mikeb commented ·
Was this recent?
This Link-local stuff behavior was recently changed in Venus Firmware.
If that was some time ago, please try again with last available firmware.
Markus
About a day ago and a hour ago
Do you see a IP address when you look in settings --> Ethernet? If yes, which one?
