Hi ! I want to know if the easysolar have an overtension protection from grid input ? (220V)
Thnak you
Thnak you
The Easy has a Multiplus inverter/charger onboard, and the specs will be the same: https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-inverter-charger--800VA-5kVA-EN.pdf (187-265 Vac). That can be changed if it doesn't suit.
I've seen this specification, but it's not say if it as an overtension protection, juste an operationnal range...
What is the difference between an operating range and "overtension"?
For me an operating range is range when operating is not damage the product and a overtension protection, cut off power in case of overtension. In france we put some componets like that in motorhome to prevent overtension risk in many country.
5 People are following this question.
