I have had intermittent loss of signal from E24 meter (single phase ESS system) This causes the PV input to disappear off the ccgx and no charging of batteries so system is in Passthru.
I suspect the Cat 5 cables which are a real pain to get into the terminals of the E24 and with some fiddling I got the PV back but then it failed again. I had to reboot several times a day to get the PV back onto the system. The red and green lights on the USB interface flash as they should but then go off - then reappear and the go off and no PV input is showing.
Now I have rewired from the USB cable back to the E24 in 3 core cable so I know I have 3 connected cables back to the CCGX but it does not work. No PV is showing and I am running on grid not solar or batteries.
How do I check the fault cause? Is it the USB cable interface, or the meter or the CCGX?
How can I bypass the meter to at least get some solar charging input?
