maha avatar image
maha asked
Temperature Sensor at BMV-702 shows only -16° ?!
Today I installed a BMV702 Temperature Sensor. The red cable is in B1 and the black one in B2 of the shunt. The setup in 69 Aux Input is TEMP. As temperature the display of the BMV702 shows only -16° .
When I activate STS - Get.Temperatursensor in DVCC I can see that the sensor was detected.
There is no other temperture sensor in use. I don't know what's going wrong. Please help me.
BMV Battery MonitorTemperature Sensor
maha avatar image
maha answered ·
This morning I tested with a new "normal" Victron Temperature Sensor connected to the master of my parallel system. In this case I got the message "Fehler Temperatursensor". Then I connected the sensor with the slave and no error occured. In DVCC the sensor is displayed and in the VRM portal the temperature is displayed too. So it seems that something is defective in the master.
