Hello
My BMV700 screen stay 'on' (backlight), and the values are scrolling alone. I can't stop it.
Any idea ? Thanks
Hello
Any idea ? Thanks
Found the problem: the cable going from the circuit to the display is a bit long. When the electric box is closed, it applies a force on the RJ11 plug, and the contact of the ,down arrow, is always ON. Moving this cable solve temporary the problem.
Not so easy to find ...
Thanks for posting the update and solution.
Menu setting number 50 allows you to choose backlight always on or goes off after 60 seconds. Set it to OFF so that backlight will go off after 60 seconds.
However, I think you are in the setting menu already. Text scrolls when you are in the settings menu and backlight also stays on.
There is a text in the bottom left of the screen that says settings, press setup once to go back to main screen, otherwise it should leave settings menu after a couple of minutes.
Hello
Thank you for answering. I m not in the setting menu, but in the visualisation menu. I cannot change anything, as the lines are always scrolling.
Does this still occur after resetting the unit and making sure the buttons physically press in and release?
Hi
Physically, the buttons seem to work, we can feel the pressing and the release. The problem could be electrical inside ...
About resetting, how can I do it without BT interface, and without buttons answering properly?
Thanks
5 People are following this question.
