mathiash avatar image
mathiash asked
BMV700 power supply cable
This might be a stupid question, however just want to make sure.
The pos. supply cable of the BMV700 is simply a power supply?
So I might as well connect it to e.g. "Votronic Plus-Distributor 6" which is then connected to the battery with other devices.
BMV Battery Monitor
wkirby avatar image
wkirby answered ·
It powers the BMV, yes. Connecting it into the distribution board is probably OK.
However it is also the Voltage sense wire. Ideally it should be connected directly to the + terminal of the battery so that its readings are not affected by the Voltage drop over other cables in the system.
mathiash answered ·
The cable to the battery is rather short ... I will give it a try.
Thanks.
mathiash answered ·
@WKirby basically similar question to the Cyrix-CT-120.
My plan was to connect port 85 to the distribution board as well. Guess answer is the same? Manual says to use a fuse with 0.1A ... I do not have this, so used 3A.
wkirby avatar image
wkirby answered ·
No, 85 does not measure Voltage, it is just a control signal, so you can wire that where you like.
3A fuse will probably be fine, just make sure the wire can take 3A in case of a fault.
