Riaan Barkhuizen avatar image
Riaan Barkhuizen asked
Limit Inverter Power and Color Control Firmware v2.60
Hi There,
Does anybody know why limit inverter power is again affecting MPPT performance? Noticed this again under v2.60 of the venus firmware
Best Regards
Riaan
firmware update
nickdb avatar image
nickdb answered ·
Limit inverter power is a global setting that is active 100% of the time whether discharging from batteries or powering loads from PV.
I asked for a feature request where a different limit could be set for each schedule so that you can effectively have two different limits, one when not charging to control battery discharge rate and another when charging so PV usage wouldn’t be throttled.
The current implementation is very limiting.
dcsonka avatar image
dcsonka answered ·
Hi, I have also suggestions on what enhancements could be done on the inverter limit power front.
See my report in the attachment.Limit inverter power.pdf
