dam avatar image
dam asked
Maximum power pass through possible on Multiplus II 32A?
what is the maximum power that can go through the "Critical Charges" in multiplus II?
I know that without the presence of the network I can only inject with the inverter 2400w.
Basically I wanted to know if it's possible to "load" the whole house (32A) into ACin
Explaining .... if you have contracted from network 32A of the network,
can I pass this entire chain through the multiplus II before entering the house distribution board?
Multiplus-II
The specific specification I think you are asking about is the AC input current limit, or AC transfer switch limit. This is available in the data sheets for each product.
For the current Multiplus-II, the AC input current limit/AC transfer switch limit is 32A. Though this is the LIMIT, so it is best to leave yourself some additional room in the design.
https://www.victronenergy.com/upload/documents/Datasheet-MultiPlus-II-inverter-charger-EN.pdf
So yes, you can load the whole house through the AC-Out 1, and the grid will support it.
However why not use as intended, with the essential loads (fridge, lights, communications) on the AC-Out 1, and leave the big loads on the AC-Out 2. This will mean the inverter will not overload when the network is unavailable, but will support when it can.
4 comments
dam avatar image dam commented ·
Would there be an advantage, at this level, in the previous multiplus of 3000 in the 50A version of transfer? and a multiplus 5000? or does this latter multiplus II have other advantages besides the disin?
In the event of a grid failure, could one way of increasing the number of essential loads in AC-1 be, for example, add a grid tie inverter I already have (fronius ig30) in AC-1 to increase the maximum 2400w of multiplus-II? To do this, I placed my meter imerssun next to AC-1 to divert the amount that might exist when the batteries are fully charged by the II
markau avatar image markau commented ·
Hi Guy,
What is the maximum inverter output in Watts of the Multiplus-II for 1 minute (overload) assuming 24 degrees with fan-forced cooling? Note our mains will be connected and current limited to 10 A 230 V/AC. 2x LiHE 100 Ah will be connected with Lynx Ion 1000A BMS. No solar or generator will be connected.
Thanks Mark
Hi Mark,
Please ask in a new question. I am sure others would also be interested in finding that info.
Hi Guy,
Please see link to new question.
Thanks Mark
