markau avatar image
markau asked
Maximum inverter output in Watts of the Multiplus-II for 1 minute (overload)
What is the maximum inverter output in Watts of the Multiplus-II for 1 minute (overload) assuming 24 degrees with fan-forced cooling? Note our mains will be connected and current limited to 10 A 230 V/AC. 2x LiHE 100 Ah will be connected with Lynx Ion 1000A BMS. No solar or generator will be connected.
With 6.5kW of purely resistive load (resistive heater) and mains connected (supplying 10 A 230 V/AC = 2200 W) how long can you run the Multiplus-II for before it trips? 1 minute is our requirement which we may need to change.
Is it possible to change the overload settings as we have forced crossflow cooling?
Thank you for your assistance.
Multiplus-IIMultiPlus Quattro Inverter Charger
Anil Ghatikar avatar image
Anil Ghatikar answered ·
You might find the webinar by Victron on inverter overload useful
https://youtu.be/4SXtGIx0x5w
