carl-damm avatar image
carl-damm asked
SBP operation
Just trying to understand the remote switch operation be for installing.
This system will be load only on a small yacht. All charging will be between battery bank and SBP.
No integration with other equipment. Simple cut off to protect deep discharge.
Can the remote be use to override the cut off and force a reconnect?
IE to temporarily bypass for emergency radio transmission, operate emergency lights etc. While charging system is brought on line.
Battery Protect
