I have a solar charger MPPT 100/30 connected to the Gerbo GX and also a MPPT control connected to the Gerbo GX. Is this an supported setup or does the system only allow one controller?
That was not the answer I hoped but thank you for the clarification!
Everything you can see with the MPPT control you can also see at the Cerbo GX.
Only the settings can't be changed directly at the Cerbo.
But if the Cerbo is connected to the internet you can use the VictonConnect-Remote feature.
https://www.victronenergy.com/live/victronconnect:start#victonconnect-remote_vc-r_configuration_and_monitoring_via_vrm
28 People are following this question.
