Hi
Can i use a GX Touch 50 on my Easysolar 2 GX to display information?
REgards, Stig
Hi
REgards, Stig
No, the GX touch 50 is only for the cerbo GX.
As long as the EaysSolar II GX is connectet to your LAN you can access the remote console from every device by entering the IP or " venus.local " into a browser.
Thanks Matthias!
I guess i just buy and use the Touchscreen for the REC Q BMS to get a good remote visible battery status then.
I need an easy and clear SOC and system status when Im not at the cabin but others are.
You can use the VRM remote console for that.
https://www.victronenergy.com/live/ccgx:start#remote_console_on_vrm_-_setup
25 People are following this question.
