n-dee avatar image
n-dee asked
menues missing in cerbo
Hi together,
Right now I was comparing the settings of the cerbo of my friend with mine.
Both are on v2.60 stable but his cerbo is missing menues likeNMEA in services or AC feed in limiting... How's that?
Is there a possibility to do a "factory reset" ?
regards,
Andy
cerbo gx
Hi @N-DEE,
There is no user accessible factory reset for GX devices, but if there was I don't think it would make a difference in this case. It is normal and expected that not all menus are available to all systems.
For example,
The NMEA menu will only be available when MQTT (LAN) is also enabled, then it will be revealed.
Then AC Feed in limit will only be available when there is a compatible export grid code and ESS assistant loaded on to MultiPlus, and a compatible PV supply connected that is set to allow export.
If there were any other specific menus missing, I might be able to explain why they are not available.
n-dee avatar image n-dee commented ·
OK got it, thanks!
n-dee avatar image n-dee n-dee commented ·
Ok lets check the AC Feed in limit.
We both have ESS assistant and PV supply connected.
