Multiplus Compact showing battery 0 v , Alarm Led alternativly blinking with yellow/Green LEDs. Also charger Not working
BMV 700 showing 13,3 V, battery fully loaded
Reset to factory did not work
What can i do?
What can i do?
try reinstalling the firmware using the VE config program.
check all fuses ( there is a fuse inside the unit and this could be blown for some reason)
THX, i already reinstalled the Firmware twice successfully, the fuses are ok
Configuration with victron connect and interface mk3 is possible, Victron Connect Shows battery 100%, but 0 Volts, Red LED ist blinking altern. with Green+yellow LED,multiplus won't start, even No function with the inverter-generator
THX for advice
27 People are following this question.
