rajathsasidharan avatar image
rajathsasidharan asked
Phoenix inverter 48/1600 BMS integration via Venus GX
Hello Victron Experts,
We have a system with 2 X 250/185 Ve CAN Mppt and 1 x Phoenix 48/1600 battery inverter.
We plan to get the system integrated to BMS via Venus GX using Modbus TCP / IP.
We are able to get the values from 1 Mppt charge controller using unit ID 100. Unfortunately, no values are being able to call from PHoenix inverter.
The device has been recognized by the venus GX, and under services> modbus TCP> unit id 245 is indicated.
Please advise.
All devices are updated to the latest firmware.
Thanks
Phoenix InverterVenus GX - VGX
Hi @rajathsasidharan
I've moved your post to the 'modifications' section, as that is where Modbus expertise is.
first: do you run Venus OS 2.60? if not please try that first.
