CCGX manual says that the supplied DC power cable includes an inline 3.15 A slow blow fuse. When CCGX is installed in a system having VE Bus BMS and MultiPlus it's instructed to connect CCGX power cable to BMS load disconnect connector. However, BMS manual says that source current limit for the load disconnect output is 2 A.
Is the load disconnect output of the VE Bus BMS sufficient for powering the CCGX?
