Some Venus devices have both Ethernet and WiFi each with its own MAC address.
When both interfaces are connected to Internet which MAC adress will be used for registering to VRM
What happens when the VRM registered interface is down.
Maybe it is possible to register more MAC adresses for a VRM account and activate the ones you need.
Hi @Peter Buijs, the same VRM Portal ID is always used, and doesn't relate to which network interface you're actually using.
So when I have internal LAN configured to connect to VRM my VRM ID relates to the MAC addrees of the LAN interface.
If I later on change the configuration to connect with external WiFi USB my VRM connection still is there?
Hi, Yes. The vrm portal id remains the same, irrespective of the used interface.
25 People are following this question.
