ray-mont avatar image
ray-mont asked
VRM shows none exciting device/ double device
Dear all
running on rpi version 2.54~1
unable to remove device 288 inverter
vrm is showing device 288 being my inverter but 288 Is already used by my bmv 700
290 is now my inverter
after removing all devices form the device list and disconnecting the usb cables, restaring the rpi even using. The Firmware 2.53
the 288 inverter is every time coming back in on the VRM website on the tab advance
how can this be solved?.
VRM
Hi @Ray_mont, we’ll look into this.
its no functional issue right? Ie you can monitor and see everything you want on the VRM Portal?
ray-mont answered ·
morning @mvader (Victron Energy)
i can use the VRM portal with out any problem
it was just to make victron aware of it
ray
