dgmar-ni avatar image
dgmar-ni asked
Can easysolar 5000W be 60Hz 120?
The spec sheet for EasySolar 48/5000/70-100 is 230V 50Hz for inverter output. But also details that can be adjusted to 60Hz and to 240V. If our grid is 120V 60Hz do we have to ask the change before to order or is this a configuration that can be done before the installation?
Regards.
EasySolar All-in-One
No it can't be switched from 230V to 120V and there is no 120V model available.
The only thing you can do is to buy all parts separately (MultiPlus is only available as 24/3000 so you have to use a Quattro 48/5000).
