juergen pflug avatar image
Venus GX - Modbus TCP - incorrect values for "User yield"?
Hi
I am connecting via Modbus TCP to a local Venus GX.
Everything works fine except for the readout value of Register 790 - "User Yield"
The "Victron Connect" app shows the CORRECT values and the readout works as expected
BUT the
2nd MPPT charger connected to VE.Direct 2 port. show different value.
According to the "CCGX-Modbus-TCP-register-list.xlsx"
Unit ID /DeviceInstance Remark
245 258 CCGX VE.Direct 2 port, Venus GX VE.Direct 1 port (ttyO2)
243 260 Venus GX VE.Direct 2 port (ttyO4)
I compared the readout via QMod Master and here are the results .
the first charger shows the correct value via Modbus:
The 2nd one shows different values:
According to the register list:
Address Type Scalefactor Range
790 uint16
10 0 to 6533.6
The readout value is at least 1 digit to short!
The value should have been ~ 72670 or so
This is not critical
but I was wondering if this is just a "small bug" in the
ModBus TCP mapping on the "Venus GX" ?
As far as I can tell, all the other values seem to give the correct values!
Can anyone confirm this behavior or am I wrong here?
Best regards
Jürgen
Venus GX - VGXModbus TCP
juergen pflug answered ·
Is there someone from VICTRON reading here?
Share
