melonentier avatar image
melonentier asked
Settings Depth of discharge offgrid
Hi
My setup:
Multiplus 2 5000
Byd b box pro 13.8
Im searching for the settings for depth of discharge setting. I can only find it at ESS but its not allowed to activate it running an offgrid version
I would like to shut down the system at 15% and reactivate the inverter at 18%.
Thanks it andance
BMV Battery Monitorbattery capacity
Alexandra avatar image
Alexandra answered ·
@Melonentier
You can set it using ve config on the inverter tab. Check shutdown on low SOC and set your percentage there. You will need to enable battery monitor on the general tab first.
9 comments
melonentier avatar image melonentier commented ·
Thanks for you answer.
I activated the battery monitor at the general tap and entered the capacity.
At the inverter tap i can only find
DC imput loq shutdown 37.20volt
Dc imput low restart 43.6volt
Dc imput low pre alarm 43.6volt
Im searching for the settings at % of battery depth of discharge.
intra avatar image intra melonentier commented ·
I thought that when you use the ESS assistant it ignores the inverter tab shutdown values.
https://www.victronenergy.com/live/ess:design-installation-manual
Alexandra avatar image Alexandra ♦ intra commented ·
It is not recommended to use ESS in an offgrid setup.
@Melonentier you may need to update ve config then, this is the version i am running.
melonentier avatar image melonentier Alexandra ♦ commented ·
Hello alexandra.
Im running the same version but i cant see the shut down at soc...
90.04.220
Is there any seting need to be done to see it except the battery monitor?
Alexandra avatar image Alexandra ♦ melonentier commented ·
@Melonentier
I have no idea on that. Sorry.
When i open ve config and open a new remote file with full options i can edit the settings for soc restart. At the top there is written quattro.
But when i open the file i download from my inverter multiplus im not able to edit the setting. Is there anything where i can switch to full options?
@Melonentier
Again I have no idea. Maybe switch tactics - try Victron Connect for local programming. I see the option there as well, I am using the demo library.
Are you using VRM or and MK3?
I tried both, vrm and mk3 same results.
I need a password for victron connect to edit settings, whats the pw?
@Melonentier
Another thought here is the firmware on your inverter up to the latest release?
melonentier answered ·
I updated the firmare of the multiplus via mk3 and victronconnect to 470. After this the setting popped up to edit. The update resets all the settings make sure to save it first.
Thanks fpr your help!
Victron BMV battery monitors product page
