tomham avatar image
tomham asked
Convert IP65 extension cable to SAE?
I have an SAE quick connect mounted to the outside of my battery box for when I want to plug in the solar panels without accessing the battery itself. It has a fuse between the quick connection and battery.
What I was wondering is if I could convert the Victron 2M extension cable into an SAE connector so I could use that same SAE quick connection when at home and plugging in with the IP65 charger, again so I don't have to access the battery but still being able to use a connection I already have set up to the battery
Would converting a Victron 2M extension cable to SAE connector create any problems for charging normally with the IP65 charger?
wiring
