alex-savidis avatar image
alex-savidis asked
AGM charge settings Victron 90Ah AGM
Hi, I have a 270W solar PV module with a Victron Smartsolar MPPT 100/20 charge controller connected to a Victron 12V 90Ah AGM battery.
Please could you someone confirm that the correct battery type preset setting on the charge controller should be Gel Victron deep discharge( 1). I read a similar post and the official response was that this is the most appropriate setting for AGM batteries but the specific battery parameters should be consulted. I can't find a detailed datasheet for my battery (Victron part number BAT412800084). Maybe someone at Victron could confirm?
Also, I've set the maximum charge current to 18A (which is 0.2C). Does this setting seem appropriate?
Thank you
Alex
MPPT SmartSolarAGM Battery
MPPT product page
VictronConnect manual
PWM or MPPT
MPPT calculator
MPPT codes
