tkrull75 avatar image
tkrull75 asked
Multiplus-II 48/5000 efficiency curve
Hi Victron team - are you able to share the efficiency curve for the Multiplus-II 48/5000. I realise you have one for the 24/3000 in your whitepapers - a similar curve for the 48/5000 would be greatly appreciated
Thanks
Toby
Multiplus-IIMPPT Controllers
elel avatar image elel commented ·
Hi @Guy Stewart (Victron Community Manager) , mine is also a Multiplus-II 48/5000 and is now using the curve of 24/3000 to design the load pattern of the system in order to achieve the best efficiency as far as possible. It would be good if you can also provide the efficiency curve of Multiplus-II 48/5000.
raphael avatar image raphael commented ·
@mvader (Victron Energy)
Could you post the efficiency curve for the MultiPlus-II 48/5000?
Like I found in this document from 2018 for the MultiPlus-II 24/3000:
Output-rating-operating-temperature-and-efficiency.pdf
So far I could only find the efficiency curve for:
  • MultiPlus-II 48/3000/35-32
  • MultiGrid-II 48/3000/35-32
and:
  • Phoenix Inverter 24/3000
  • MultiPlus 24/3000/70
in this document on the website (15-05-2018 Rev 04):
https://www.victronenergy.com/upload/documents/Output-rating-operating-temperature-and-efficiency.pdf
Is it possible to publish further documents on larger inverters?
I know that the curve might not differ much, but for larger system design, it would be useful.
raphael answered ·
MultiPlus-II 48/5000/70-50 efficiency curve
As promised, there ist the efficiency curve for discharging (DC -> AC)
Measurement DC: Victron Smart shunt (auccuracy DC-Power: ± 0.7 %)
Measurement AC < 16 A: Gossen Metrahit Energy (accuracy AC-Power: ± 0.7 %)
Measurement AC > 16 A: ELV Energy Master 2 (accuracy AC-Power: ± 1.5 %)
-> The efficiency accuracy is ± 1.4% < 16 A
-> The efficiency accuracy is ± 2.2% > 16 A
(The last 5 measurement points are probably a bit less accurate, because the measurement range of the ELV Energy Master was exceeded)
(You have to multiply the efficiency of each measuring point with the efficiency accuracy to get the actual efficiency error-range in %)
You can find the measuring points in the attatchment:
Also I measured the efficiency curve for charging (AC -> DC)
Measurement AC: ELV Energy Master 2 (accuracy AC-Power: ± 1.5 %)
sorinpopa avatar image sorinpopa commented ·
Bravo!!!
raphael answered ·
Could you please share the Efficiency Curve for the MultiPlus-II 48/5000
Thank you in advance!
I am tired of waiting...so I orderd some resistiv loads and I'll make my own graph.
I'll publish the curves by March 2022, if all parts arrive in time.
peter-van-duijn avatar image
peter-van-duijn answered ·
@Guy Stewart (Victron Community Manager) - we would also be interested in this curve.
Could you please share with us? Thanks in advance.
iand avatar image
iand answered ·
And the 48/10000...
Marco Nijholt avatar image Marco Nijholt commented ·
I would like to know for the 10kva version too
raphael avatar image raphael Marco Nijholt commented ·
I wished, Victron would send me one over for testing.
baxter avatar image
baxter answered ·
Hi, could you pls share it for the Multi II 48/5000 ?
TIA
Paul avatar image
Paul answered ·
Many thanks for sharing! Very useful for me!
