james-ftp avatar image
james-ftp asked
Victron d-bus api - list connected products?
When using the victron dbus api, is there a way to list the products connected to the system? I.e. for addresses of products in the form "com.victronenergy.[product type].[tty name]" or ''com.victronenergy.[product type].[interface]_di[device instance]_uc[unique-number]'', if we don't know the tty name or identifier of a product before hand, is there a way to display/discover them?
Venus OS
mfriedel avatar image
mfriedel answered Ā·
Take a look at the dbus-spy.
laurenceh avatar image
laurenceh answered Ā·
Looking at the dBus tool:
dbus -y com.victronenergy.system / GetValue
I think this lists the connected services that are being published on the dBus
It certainly lists the extra service my code is publishing to the dBus like this
 'AvailableTemperatureServices': {
         'com.victronenergy.temperature/23/Temperature': 'Generic Temperature Input on Temperature sensor input 1',
         'com.victronenergy.temperature/24/Temperature': 'Generic Temperature Input on Temperature sensor input 2',
         'com.victronenergy.temperature/25/Temperature': 'Encased i2c AM2315 on i2c device 1',
         'com.victronenergy.temperature/26/Temperature': 'Custard Pi-3 8x12bit adc on Temperature sensor input 3',
         'com.victronenergy.temperature/27/Temperature': 'Custard Pi-3 8x12bit adc on Temperature sensor input 4',
         'com.victronenergy.temperature/28/Temperature': 'Custard Pi-3 8x12bit adc on Temperature sensor input 5',
         'default': 'Automatic',
         'nosensor': 'No sensor'},
I'm pretty certain as more devices are connected their service paths will be published on the dBus in this and other lists, I can see details for the following on my test system with nothing connected:
'AvailableBatteries':
'AvailableBatteryMeasurements':
'AvailableBatteryServices':
Sadly it does not pick up my i2c 'Humidity service'
'com.victronenergy.temperature/25/Humidity': ''Encased i2c AM2315 on i2c device 1'
So it seems it does not add everything only the things it knows to look for.
There is also a service mapping however it does not seem to map many services:
'ServiceMapping/com_victronenergy_settings_0': 'com.victronenergy.settings',
 'ServiceMapping/com_victronenergy_temperature_23': 'com.victronenergy.temperature.builtin_adc5_di0',
 'ServiceMapping/com_victronenergy_temperature_24': 'com.victronenergy.temperature.builtin_adc3_di1',
 'ServiceMapping/com_victronenergy_temperature_25': 'com.victronenergy.temperature.i2c_id00',
 'ServiceMapping/com_victronenergy_temperature_26': 'com.victronenergy.temperature.RPi_adc0_id00',
 'ServiceMapping/com_victronenergy_temperature_27': 'com.victronenergy.temperature.RPi_adc1_id01',
 'ServiceMapping/com_victronenergy_temperature_28': 'com.victronenergy.temperature.RPi_adc7_id02',
As these are all on the dBus you can write python scripts that will extract the relevant data and use it when creating python objects to attach to particular services.
jeroen avatar image jeroen ā™¦ commented Ā·
dbus -y without any arguments will list all available services.
0 Likes 0 Ā·
