rhys123 avatar image
rhys123 asked
Guide on EasySolar Setup
Hi
I'd like to set up a 12v EasySolar with a 200ah Victron Lithium battery and a Colour GX Panel.
It will be going in a boat with no alternator. So just Solar or Shore Power for charging and the system will provide DC power and AC from the inverter.
Could I please get some advice on what cables I need to run to set the system up and get everything talking to each other? And also what I'll need to do for programming?
Thanks,
Rhys
EasySolar All-in-One
Alexandra avatar image
Alexandra answered ·
@rhys123
https://www.victronenergy.com/inverters-chargers/easysolar
All the information is in the manual. You can download a copy from the link above for the Easy you are considering.
There are also data sheets available just choose from the drop down box and photos. The 12v 1600 comes with battery cables so that simplifies most of the setup.
