During all conditions, the BP doesn't shutdow
-When unplug the Remote jump
-when the battery voltage is under the Voltage Shut down.
Who can help me?
My WhatsApp number: +989127780923
Who can help me?
Do you have the IN and OUT connection the correct way around?
If these connections are reversed then the BP will not disconnect under any circumstance.
This device is MOSFET controlled. MOSFETs have this charactaristic where they will always conduct in the reverse direction even when switched off due to the parasitic body diode of the MOSFET.
15 People are following this question.
