Oliver avatar image
Oliver asked
PV Inverter assistant. What effect do the settings have on frequency regulation?
I use the PV-Inverter assistant in an off grid setup with lithium battery. At end of charge when the BMS doesn´t admit more charge, the battery voltage still rises more quickly than the Victron increases the frequency. This leads to an unstable system. Therefore I try to tune the frequency response of Victron by adjusting the values in the PV-Inverter assistant. Especially I would like to understand the effect of the values "PV inverter power" and "PV panel power" on the frequency regulation.
AC PV Coupling
