Riaan Barkhuizen avatar image
Quattro Inverter in Passthru
Hi There,
I have a Victron Quattro system that goes into "passthru" and then stays there for extended periods of time. I have noticed that this is somehow related to communication with the ET112 single phase grid meter which is connected to a color control gx.
Enabling and disabling the energy meter as well as restarting the color control solves the issue consistently.
Below is a list of components with the current firmware versions
Color Control GX - v2.54
5kVA Quattro - 2657430
Freedomwon Battery Monitor - v6.8
250/70 MPPT - v1.50
3.6kVA Fronius Inverter - 3.13.2-2
Please let me know if I'm missing something.
Best Regards
Riaan
Riaan Barkhuizen answered ·
Firmware version update on the color control solved the passthru issue.
Share
Just wondering why everything works after restarting cgx. If it was a cabling problem, probably it would stop working completely. Could it be that the energy meter stop communicating. I did see this once before, but that time the meter would not communicate at all. Is there a way to test the cable and the meter? Or is the only way to change them out and hope for the best?
2 comments Share
Hi @Riaan Barkhuizen
What is the site id?
easiest way is often indeed to swap cables etc.
Riaan Barkhuizen avatar image Riaan Barkhuizen Daniël Boekel (Victron Energy Staff) ♦♦ ·
Site ID = 64cfd9e3fec2
As you've noticed, a communication error between the grid-meter and GX device can cause this, as also mentioned in the manual (Q4 of the faq):
https://www.victronenergy.com/live/ess:design-installation-manual#faq
so start with the grid meter / cabling / etc.
Share
