Casey Pries avatar image
Casey Pries asked
FET isolator with battery charger
I just installed an FET isolator and it seems to be working fine. Is it ok if when my boat is parked at the house I connect up a standard 12V battery charger to the isolator and charge both batteries at the same time just like the alternator would if the engine was running?
Argo FET Diode
