cadoxa avatar image
cadoxa asked
Victron Quattro Aux ports not working
I have a 123 Smart BMS connected to the Aux1 and Aux2 ports of my Quattro. I'm using the ESS assistant only to control the Charger. Problem is, even though the BMS is signaling the Quattro to stop charging it simply doesn't stop. It looks as if the Quattro is ignoring the commands on those doors ...
Anyone have a clue why this is happening ? I've contacted several Victron dealers in Portugal but they dont know jack shit about the products they're selling.
Thanks
Carlos
MultiPlus Quattro Inverter ChargerBMV Battery Monitor
Hi @Cadoxa
what BMS are you using?
can you show the assistant settings?
and a wiring diagram of how you've connected the bms to the quattro?
cadoxa avatar image
cadoxa answered ·
Hi Daniel,
Thanks for your answer. Find attached 6 screenshots of the assistant's configuration. I will follow the wiring diagram ... hold on ...
cadoxa avatar image
cadoxa answered ·
The BMS is a 123 Smart BMS
https://123electric.de/gb/?gclid=Cj0KCQjwoub3BRC6ARIsABGhnyZ_NtcK5AgdhMbC6jmXSZkzewWUeDbnhXy1aUX4a195D0xmzYfQpVcaAkWiEALw_wcB
Charge relay is connected on Aux1 (pins 1 and 2) - Allowed to charge
Loads relay is connected to Aux2 (pins 1 and 2) - Allowed to discharge
Let me know if it helped ...
