I am working on an existing system installed with 1 x Colour Control GX, BYD batteries, 2 x Solar MPPT 250-85 charges and 1 x Inverters. Currently, the BYD batteries are connected to the Colour Control GX via CAN bus, the Solar MPPT 250-85 charger is connected on the VE Direct and inverter is connected to the controller via VE Bus
I are currently looking at augmenting the system with additional solar. There is only two VE direct port in the CCGX controller and one VE direct port on the solar charger. Is there any way I can connect the additional solar charger to the CCGX by paralleling the connection?
Thanks
