I have a new 12/3000/120 230v being charged by a 5kva generator off grid. I have new 750 amps of open lead acid in 2c cells. After the first charge my multi plus goes direct to float, I have taken 275 amps from them so they should go to bulk?
https://community.victronenergy.com/questions/52921/multiplus-not-bulk-charging.html
This system has a similar issue. The suggestion is to switch off the multi and switch it back on.
15 People are following this question.
