faraday avatar image
faraday asked
Ac In At EasySolar 12/1600: 70v Ac Even though the Grid is Not connected
Hi there,
I just observed something strange: The Grid is Not connected But when I Turn on the Switch for the Ac Input there is 70volts ac on the AC IN.
An IF i do connect the Grid, the whole unit goes into alarm mode.
Does anybody have an idea or has Seen this behavior before ?
EasySolar All-in-One
Hi @Faraday
Did you properly ground your inverter casing? and where are you measuring the voltage exactly?
faraday answered ·
Hi @Daniël Boekel (Victron Energy Staff),
I measure the voltage Right at the ACin 16A connector between L and N. Well, on the extension cable actually.
the casing is well grounded by using the proper bolt.
I did have the grid connected to the Unit but the circuit braker fuse Flicked - so I unplugged it and tried to find whats wrong. The Internal breaker did Not flick. Since then the Unit goes into Alarm (only Alarm LED on) - that state is not described in the Manuel unfortunately.
faraday answered ·
It is actually 72,5 V AC:
and here is Video of what happens when grid comes in: Link to Video
4 comments
Hi @Faraday
Can you please measure this at the terminals of the inverter?
Also please measure with the breaker open and input connected.
faraday avatar image faraday Daniël Boekel (Victron Energy Staff) ♦♦ commented ·
So, here are the measurements I Took today right on the Pins of the Terminal.
ACin breaker closed:
Between L + N: 68,1 VAC 50,00 hz
Between L + ground (chassis): 230,00 Vac 50,00 hz
Circuit breaker open, Inverter Mode ON:
Between L + N: 0 volts
Between L + ground (chassis): 0,035 Vac 50,00 hz
when the ACin circuit breaker is closed and i Switch the invertiert to Off, the voltage between L+N Drops to zero as it would when i Open the circuit breaker.
Will do the measurement with breaker open and connected input tomorrow. Today it was not possible.
I Hope the Stated measurement are already usefull.
faraday avatar image faraday faraday commented ·
to the 2nd measurement with closed breaker:
Shouldn‘t the safety relay avoid exactly that?! The 230 vac from the inverter Are now let through to the output !?
Daniël Boekel (Victron Energy Staff) avatar image Daniël Boekel (Victron Energy Staff) ♦♦ faraday commented ·
Hi @Faraday
Yes this should not happen and it sounds like a part of the 'feedback relay' is stuck,
Please contact your dealer for repair of the unit.
