lopezjm2001 avatar image
How to increase communications length between CCGX and MPPT 150/60?
Newby here, first post. It probably has been asked before.
I have a Victron Smart Solar 150/60-Tr on order. Planning to use a CCGX with my MPPT 150/60.
The Victron site says that a VE.Direct cable is limited to a maximum length of 10 metres between a CCGX and a MPPT charger. My CCGX will be in the kitchen about an 18 metre cable run to the MPPT 150/60Tr. So a VE.Direct cable is out.
Is there an alternate method of stablishing communications between a CCGX and a MPPT 150/60 Tr when located > than 10 metres apart? TIA.
MPPT - Solar Charge ControllerCCGX Color Control
JohnC avatar image
Hi @lopezjm2001
A broader approach, especially as you may have other kit connected to the GX, is to leave it near the kit and just use an ethernet/wifi link to duplicate it's functionality *wherever*.
One of the big attractions of the GX is web access (VRM). So you can do both at the same time, same wire/wifi.
Even if you didn't have it web-routed, a direct link-local connection can be made anyway.
The CCGX has a screen, but there's other GX models that don't. And this is why. It isn't actually essential when you can byo.
3 comments Share
Thanks. My main reason for using a CCGX is to use the heartbeat signal to hook up an LG Chem 13 battery using a VE.Can to CAN-bus BMS type B Cable. I did not think of using a USB wifi dongle or a USB ethernet adapter. Having a fail-over is a good idea.
@lopezjm2001
Just to be clear. I wasn't talking failover, but full remote access/control of the GX even from the other side of the world. Via it's ethernet port or usb-wifi (approved dongle or onboard with some GX's).
The LGChem batt would likely use the local GX Can port, but I suggest you check this further before heavily committing, there may be issues.
This link may need updating: https://www.victronenergy.com/live/battery_compatibility:lg_chem_resu
Maybe ask a separate question to help determine what the current situation is with these batts.
I have already been reading that link and all the LG Chem questions on the forum. It is very fluid. Hoping that Victron will come up with an off-grid solution.
Hi @lopezjm2001,
This is covered briefly in the GX manuals, the supported solution is to use an Active USB extension cable, and the VE.Direct to USB adapter.
Share
