I'm installing a solar power system based on EasySolar 48/5000, which includes Color Control GX. It would be more convenient if the CCGX could be located on the other side of a wall, some 1-2 m away from the EasySolar. Can it be done simply by using extension cables?
If this is not possibel, is the GX Touch 50 compatible with CCGX and does it give all the functions of the CCGX?
