Gabriel Tanasescu avatar image
Gabriel Tanasescu asked
Somebody Installing this Ac Coupling System? Grid connected. For zero feed-in .
Hi Gentelmens .
Please help to me for to have an a system to working properly.
All Symo are upgraded to the last Firmware .
The Grid connected (#2) Slave Symo 8.2 (light) is without datamanager witch is connected to the Victron Ac1 in . grid setting is Country code (Romania)
The (#1) Master Symo 8.2 (web ) is with datamanager witch is connected to the Victron Ac1 out. grid setting is Country code MG 50 .
In this situation: the (#1) Master Symo 8.2 is always in braked by Victron when zero feed-in on .
When I switch off the zero feed-in ..this Symo go to give the power from Pv.
If you see ....is nonsense don't working the booth (#1) Master Symo 8.2 because the battery is low
What is a right settings in this situation? from Fronius side and from Victron side ? because I don't want to feed-in any power to Grid from both Inv Fronius Symo
AC PV Coupling
