maciek avatar image
maciek asked
Temperature sensor not showing any reading
On our boat, I have a MultiPlus 12V 3k + two battery banks (house and starter) + two VE.Net battery monitors on each bank, all wired to VE.net panel. Each monitor, and the MultiPlus has its own temperature sensor wired to a negative terminal of the battery. On the VE.net monitor, the temperature is showing all the time as 20C, which I believe is the default value when the readout of the sensor is not possible. The actual ambient temperature where I am is higher than 20C, so it should show at least that.
How do I troubleshoot that?
Regards,
Maciek
Temperature Sensor
Victron temperature sensor disambiguation table - which product supports which sensor
