Abdulbasit Bushra avatar image
Abdulbasit Bushra asked
How to connect multiple Fronius to the GX Color Control?
Dear All,
Please help me how to solve this configuration.
we have installed 33KWp system with three 10KW Victron quadros and 3 Fronius symo 10KW. everything is working perfectly.
the only thing is How to connect the Fronius to the GX Color Control?
Thank you
Abdulbasit
AC PV Coupling
If the Fronius' have the web module installed you can use ModBus/TCP.
https://www.victronenergy.com/live/ac_coupling:fronius
https://www.victronenergy.com/live/ccgx:modbustcp_faq
If not you can use an ET340 for each(or one for all).
https://www.victronenergy.com/live/energy-meters:et340
maha avatar image
maha answered ·
First of all you have to configure the Symos:
Change the following settings in the Fronius web interface:
  • In the Fronius setup menu, set Data export via Modbus to tcp.
  • In the same menu, set Sunspec Model Type to int + SF
  • In Settings→DNO Editor, make sure dynamic power reduction is set to No limit (this is the default).
  • In Settings→DNO Editor, make sure that in the 'Controlling Priorities' section that 'Controlling via Modbus' is set to be priority 1.
Use the Fronius Zero feed-in active menu item to double check that all above criteria are met. It will show No if the firmware requirement; the Data export; or the Sunspec Model type settings are incorrect.
Do not use a Fronius Smart Meter for limiting export when part of a Victron ESS System. More details about when a Fronius Smart Meter can, and can not be used is explained here.
Then you set the Symo in WLAN-state. After that you start finding the Symo for CCGX. How this works is discribed here:
2.2.2 Adding Fronius to the GX Device
AC-Coupled PV with Fronius
Hope this helps.
