Greetings
I have a marine installation, MultiPlus 12/3000, CCGX, BMV702. On a resent cruise we were at times on shore power, generator and inverter.
I am having to reset the CCGX in order to control the Multi. With the Multi master switch ON, I control the Multi with the CCGX. It seems that when I switch between the various power input options I have to reset the CCGX. Example: When last used the connection was to ShorePower and then we leave the dock and later switch ON inverter mode I have to reset the CCGX in order to get the Multi / inverter to switch ON.
The problem seems somewhat intermittent, sometimes all works OK and sometimes not. I have no alarms.
Thanks for any suggestions, Tom
M/V HALFMOON
