just-chillin avatar image
just-chillin asked
MPPT 1224-40 Temperature Sensor
The thermistor(?) on the BTS probe of my MPPT 1224-40 charge controller has broken off.
It was connected to the controller via an RJ45 connector. On each tails of the encapsulated thermistor there was a resistor soldered in series: one is 10k and the other is 76k.
I have a replacement sensor (genuine victron Im advised) that has the following characteristics : 96k at -20C (freezer), 10k at 20C (room temperature) & 1k at 100C (boiling water). Would this be a suibale sensor to solder in series with the existing resistors please?
Alternatively, can anyone advise the resistance characteristics of the BTS probe please?
Many thanks in advance
Temperature Sensor
What is a MPPT 1224-40?
Do you mean a Orion 12/24? But there is no Orion with 12/24 and 40A!?
And also the neither the MPPT nor the Orion have a T-sense...
Or the BlueSolar PWM? But there is also no model with 40A.
Can you make a picture of the device?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ JohnC ♦ commented ·
Yes, after a bit of google I also found this device.
This old manual has a terrible translation into German. :D
just-chillin avatar image just-chillin Matthias Lange - DE ♦ commented ·
Thanks to all for making the effort to respond.
Apart from getting info off google which I am (and have been able) to do myself is there no way of getting technical input from Victron themselves eg original technical design specification documentation?
just-chillin answered ·
Pictures as requested
Oh, you have a very old device.
The T-sense is not necessary for the MPPT to work.
It is optional to optimize the charging at high/low temperatures.
It looks more like RJ12 not RJ45.
Sorry but I don't know what you can use as a replacement.
Victron temperature sensor disambiguation table - which product supports which sensor
