Rob Mitchell avatar image
Rob Mitchell asked
How to detect tank level with Winnebago TrueLevel (using Mirus cells) that output Voltage
My 2008 Winnebago SightSeer 30B has something called TrueLevel non-contact sensors. Each tank consists of three pads stuck on the outside of the tank at three different levels in height to represent High, Med, Low levels of fluid in the tank. The cells being used ar Mirus cells. These cells output a small electromagnetic current that sensor if there is fluid inside the container at the location of the cell pad. Here are some readings you can expect to get.
Ground - Pin 3 (white wire): Neg battery terminal connection
Fresh Water - Pin 4 (red wire): Empty = 4.94 volts, 1/3 = 4.81 volts, 2/3 = 4.69 volts
Black Water - Pin 5 (brown wire): Empty = 4.94 volts
Grey Water - Pin 6 (grey wire): Empty = 4.94 volts, 1/3 = 4.80 volts
My question is what technology from Victron will allow me to monitor my tank fluid levels such as Grey, Blank, Fresh water and LPG tanks.
I currently own the BMV-712 and will be owning a SmartSolar MPPT 100/30 in the not so distant future.
Thanks
tank monitor
