kami avatar image
Zero Feed in for Fronius with rasperry without ESS
i want to install a Photovoltaic System in Zero-Feed Mode and Fronius symo 8.2-3-M.
I want first only run the System without a ESS but with the opinion to add it later. Is it possible to run the System at the rasperry without a Multiplus first?
Thanks a lot
Kami
Raspberry Pi
kami avatar image
kami answered ·
ok, lets try another time:
is the venus Software able to set the Fronius to the Zero-feed-in mode without an multi-ess-device?
thanks!
Kami
Share
Riaan Barkhuizen avatar image
Riaan Barkhuizen answered ·
Hi @kami
If you are a programming NINJA then you can write a script to do a type of zero export. But only if you are a NINJA.
Best is to make use of the Victron GX device.with the correct settings on all devices.
Best regards
Riaan
Share
