wattpeak avatar image
wattpeak asked
Problem with batteries
Hi,I have small instalation of Easy solar 48V 3000VA + BMV701 + 4x Victron deep discharge AGM 90Ah/12V
One month back, BMV701 stopped working . I will change it in shop, but, since this problem batteries jump to 50% of capacity as it is on the picture.
Batteries capacity was set to 50% of capacity for discharging - for bigger cycle number.
Its possible, that batteries are KO cause the bmv701 stopped working?
Next problem is, that i have in Device list MPPT 150/70 twice. thats not good too.
Thanks for any reply -
this Instalation is 1Year old, i think the batteries must be OK.
I'm little bit nervous, because if the reason is BMV, and batteries are KO, i really dont know how to claim it.
thanks
Stepan.
MPPT ControllersBMV Battery MonitorAGM Battery
I would start with checking how the inverter is programmed? Is it set correctly for your batteries? Sometimes the system needs a few good charges 100% in before syncing with battery SOC correctly through the VE bus.
Sometimes the charge controller appearing twice is because it was unplugged and the plugged in again.
